How to offset output voltage without using DC offset
Discussion in 'Homework Help' started by justaspare, Apr 10, 2016.
  1. justaspare
    Apr 9, 2016
    I'm supposed to be building a circuit that has an input from a function generator of 20v p-p, however the output measured on the oscilloscope needs to be 10vp-p with the positive side at 6v and the negative side at -4v. I have the voltage devider part covered, but I'm unsure how to go about offsetting the
    I need to do this without using the DC offset in the function generator. Would this work with just a basic amplifier or attunator circuit? The cosest thing I have found involves op-amps, and my text doesnt have anything similar to this request in it, so I'm not sure where to go from here.
  2. ErnieM
    Apr 24, 2011
    7,447
    1,628
    You can make 10vpp from 20vpp with a simple 2:1 voltage divider, which will be centered on zero.
    If you now take that same divider and connect it to -8v instead of ground the net signal will be offset by the -4 v you want.
    You can prove that by superposition, first look at the output with one than the other source shorted out, then add them together.
  3. dannyf
    Sep 13, 2015
    2,196
    417
    a summing amplifier will do - which is essentially an offset adjustment here.
  4. SLK001
    Nov 29, 2011
    852
    243
    This is like asking "How do I hammer a nail without a hammer?"
  5. WBahn
    Mar 31, 2012
    18,096
    4,920
    That was my first thought based on the title, but the TS clarifies that he is talking about without using the DC offset capability of the function generator.
  6. justaspare
    Apr 9, 2016
    That's what you get with the teacher I have. The first part of the assignment called for a voltage devider but ONLY gave input voltage and output voltage. He told me that we weren't supposed to make up the total resistance and then he made up the total resistance 45 minutes into the lab. We needed 3 different divisions, or it would have been a non-issue.
  7. dannyf
    Sep 13, 2015
    2,196
    417
    Vout = 0.5 * (Vin + 2)
