I am trying to build a little circuit to help measure voltages at various points of projects I build. Any links to similar circuits will help.
The project circuit (PrC) will connect circuit under test (CuT) to a DMM + lead
So...
Inputs to the PrC are from CuT
Output is to a DMM's + lead
PrC will have up to 20 momentary push buttons, normally open.
When one of those 20 buttons, say button A, is pressed-
current to flow between corresponding input (A) and DMM+ (so latching is required)
an LED (3mm type will do) next to it will light up stay lit
This state will only change when a different button, say button D, is pressed, then circuit A will open and circuit D will close. Pressing button for currently active circuit will make it open but this feature is not necessary if it leads to more complexity/components.
Each line will carry under 100mA, under 12VDC. Resistance to be as close to zero as possible.
I looked into relays as they have the lowest resistance, but are there better ways?
Are there boards already built with some/all of these features sold on ebay etc.?
So...
