How to measure voltage on an android
Discussion in 'General Electronics Chat' started by Pavle, Dec 9, 2015.
  1. Pavle
    Dec 6, 2015
    42
    How to measure voltage at micro usb port on android with multimeter???
  2. #12
    Nov 30, 2010
    16,661
    7,305
    Connect the black (-) lead of the meter to, "ground" or, "common". Connect the red lead of the meter to the point you want to measure. Something in the range of zero to 5 volts is to be expected.
  3. Pavle
    Dec 6, 2015
    42
    I connected black wire to the ground and red wire to red wire but is not showing anything on display.
  4. #12
    Nov 30, 2010
    16,661
    7,305
    I don't know the color codes of an Android or a USB connector. Perhaps some other person could help.
  5. Lestraveled
    May 19, 2014
    1,957
    1,217
    The connection to a Android in an input. Plus +5 volts should not be present. You might get some voltage on the data pins if there are pull-up resistors.
  6. kubeek
    Sep 20, 2005
    4,686
    805
    Which end of it? The charger or the phone?
    A charger should give 5V between the outermost terminals IIRC.
    A phone could be giving out 5V, but it just as well might not. That depends on the hardware of the phone and if it supports USB OTG.
  7. Pavle
    Dec 6, 2015
    42
    I want to know how much voltage is android giving out???
  8. Lestraveled
    May 19, 2014
    1,957
    1,217
    That would be a little difficult since the battery voltage in cell phones is about 3.6 volts.
  9. Pavle
    Dec 6, 2015
    42
    How can I do that???
  10. Lestraveled
    May 19, 2014
    1,957
    1,217
    I do not think a cell phone will output voltage on the micro USB connector. It is designed to receive 5 volts to charge the battery.
    DerStrom8 likes this.
  11. Pavle
    Dec 6, 2015
    42
    My S3 Neo supports USB OTG but it cannot provide enough voltage to otg devices.
  12. Pavle
    Dec 6, 2015
    42
    How to fix that???
  13. kubeek
    Sep 20, 2005
    4,686
    805
    The USB OTG spec says 4.4V to 5.25V, so the phone obviously needs to do a boost conversion from the battery voltage. Not too difficult with modern minitaturization, but still a hassle, which is why not too many devices have this.
  14. Pavle
    Dec 6, 2015
    42
    How to boost conversion from battery voltage???
  15. kubeek
    Sep 20, 2005
    4,686
    805
  16. Lestraveled
    May 19, 2014
    1,957
    1,217
    From https://en.wikipedia.org/wiki/USB_On-The-Go
    It does so by periodically measuring the capacitance on the USB port to determine whether there is another device attached, a dangling cable, or no cable. When a large enough change in capacitance is detected to indicate device attachment, an A-device will provide power to the USB bus and look for device connection.
    It will not provide power until it senses another device.
  17. Pavle
    Dec 6, 2015
    42
    Is there a way to power otg device without y cable???
  18. kubeek
    Sep 20, 2005
    4,686
    805
    no, unless you have an OTG host deivce.
  19. Pavle
    Dec 6, 2015
    42
    I cut android usb cable and connected red wire with red wire,black wire with black wire and plugged in usb port to pc and micro usb port to android and multimeter says 4.76 volts.
  20. Lestraveled
    May 19, 2014
    1,957
    1,217
    I am pretty sure that the voltage is coming from the PC. What happens when you open the red wire. Is there voltage on the android side?
