How to measure UV light
Discussion in 'The Projects Forum' started by embpic, Oct 11, 2013.
  1. embpic
    May 29, 2013
    187
    Hello master's
    what is main concept to measure uv light using controller?
  2. Alec_t
    Sep 17, 2013
    5,979
    1,138
    What sort of 'controller'? Do you mean a MCU?
  3. Shagas
    May 13, 2013
    802
    74
    Either use a specific Uv photodiode/phototransistor (even if they exist they won't be cheap imo )
    Or use a broad-range photodiode (easier to find) that goes down to uv range and use a physical uv colour filter as the sensor .
    The photodiode output will to go a microcontroller ADC.
    Also .. UV is anything from about 200nm to 405 nm so you need to specify what you need to measure.
  4. DickCappels
    Aug 21, 2008
    2,778
    674
    If that Hamamatsu Photonics UV sensor turns out to be too expensive, you can try using a photo transistor or photo diode designed to handle longer wavelengths and use a florescent material to down-convert the frequency into that detector's range.
  5. Shagas
    May 13, 2013
    802
    74
    Interesting , can that really be done?
  6. lasercowboy
    Oct 12, 2013
    6
    Great idea Dick! if cost is an issue, quinine (from tonic water) will do the trick nicely.
  7. DickCappels
    Aug 21, 2008
    2,778
    674
    Probably just a can of day-glo paint would work. And I am sure it would work best with the right combination of LED wavelength, florescent dye, and detector.
