The different materials with the same capacitance values have different charging times to "REACH" the peak voltage
Again, what do you mean by "reach" the peak voltage? Why won't you provide a simple sketch of the measurement you are trying to describe?The different materials with the same capacitance values have different charging times to "REACH" the peak voltage
It's what happens when using real components, it's not in a text book or college class. Yes there is co-efficient's for each material because they are made differently and "react" differently.Could you please point me to the list of coefficients for each material and how the equations should be changed?
I'm just stating my observation, but yes point me to the list also or maybe I'm wrongCould you please point me to the list of coefficients for each material and how the equations should be changed?
Can you please explain more about the "step in voltage" and the response is the voltage across the capacitorThe transient is the step in voltage and the response is the voltage across the capacitor.
Since you are questioning whether people understand the difference in what you mean by those terms, why won't you define what you mean by these two terms? Is that so much to ask?Ronv ,
isn't that measuring the transient response of a capacitor or the charging time of a capacitor? some people don't know the difference between the two or think they are the same thing. Do you know the difference between the terms
Charging time means: you're measuring the charging time of the capacitor + an external resistor = RXC = time constantisn't that measuring the transient response of a capacitor or the charging time of a capacitor? some people don't know the difference between the two or think they are the same thing. Do you know the difference between the terms
No, not at allQUOTE]Or are you thinking about frequency response?
When you reply to anyone then you should adding their ID that it will easily to identify whom you reply to.QUOTE]Or are you thinking about frequency response?[
No, not at all
Chdarging time means: you're measuring the charging time of the capacitor + an external resistor = RXC = time constant
Transient Response means: you're measuring the charging time of just the capacitor + ESR + ESL + Leakage = Time constant or you're measuring how long it takes for the capacitor to "REACH" the peak voltage of the inputs step voltage. *** THERE IS NO EXTERNAL RESISTOR USED***
Yes the transient response relates to a circuit, like measuring the input and output of an IC logic gate. In inject a clean logic step input and the output of the logic gate will be charging to the peak voltage in nanoseconds to the logic step input voltage. This is the transient response of a IC logic gate test.You might be able to calculate it using your method, but you can't measure it because the resistor now becomes the ESR of the capacitor and is inside of it.. Usually transient response relates to a circuit.
You just press on the "Reply" button on the right bottom of the messages whom you like to reply.ok I will scottwang but how do you add their id?
Ok thanksYou just press on the "Reply" button on the right bottom of the messages whom you like to reply.
TS first defined his use of ESR in post #32.I know I'm very late to the party, but isn't this whole thread about measuring ESR, the impedance of the capacitor, at some defined frequency? Use an ESR meter. You don't need any fancy method to analyze the time profile of voltage.
by Dale Wilson
by Jake Hertz
by Duane Benson
by Jake Hertz
