how to measure the distance between two objects in motion
Discussion in 'The Projects Forum' started by electrazy, Jan 20, 2009.
  1. electrazy
    Jan 19, 2009
    21
    some apparatus that can be developed in lab using sensor ic transmitter etc
    ....ok let me make through an example
    for eg.- we have to measure the distance between two moving cars (any vehicle) moving with variable speed
    while the full apparatus is in the car running behind no part of device is placed on car in front
    car in front can be made of any material (reflector or non reflector) and can be of any shape
    both cars are in same plane
    assuming relative speed to be 1-16 meter per sec
    info is required in real time and output should voltage or current and proportional to distance
    distance must be measured continously(as it is changing with changing speed)
    max distance between them can be 8-10 meter
  2. RiJoRI
    Aug 15, 2007
    536
    26
    Sounds like a continuously-operating speed gun.
    --Rich
