How to measure speaker current
Discussion in 'General Electronics Chat' started by PSnetwork, Aug 15, 2013.
  1. PSnetwork
    Apr 1, 2013
    30
  2. wmodavis
    Oct 23, 2010
    737
    150
    Series Ammeter, voltage drop across a series resistor, Clamp on ammeter, etc......
  3. PSnetwork
    Apr 1, 2013
    30
    I Know that... i meant how to calculate it if i dont have the speaker itself.
    only with the speaker info.
  4. wmodavis
    Oct 23, 2010
    737
    150
    That is quite different from what you said in the OP.
    I could only go by what you said not what you say you really meant after the fact.
    And how are we suppose to know just what you know? If you do not provide the pertinent details it's 'by-guess-and-by -gorsh'. My crystal ball is cloudy. Sorry. But I meant to answer what you really meant to ask.
  5. PSnetwork
    Apr 1, 2013
    30
    ok bro just can you tell me how do i calculate the speaker current only with his info sheet?
  6. wmodavis
    Oct 23, 2010
    737
    150
    At what frequency? Do you know the formula relating power, current & resistance?
  7. crutschow
    Mar 14, 2008
    13,518
    3,386
    Well "bro", the speaker impedance varies with frequency, as the graph shows. So the current will vary with both the voltage and frequency content of the signal. You divide the signal voltage at a given frequency by the speaker impedance for that frequency. If the signal is more than a single frequency then you must integrate the current for each frequency component to get the total current.
  8. PSnetwork
    Apr 1, 2013
    30
    you have the info below. I think that the currents formula should be, I=P/V.
    anyway i dont sure whats the voltage of the speaker.
    http://www.madisoundspeakerstore.com...ne-wide-range/
  9. wmodavis
    Oct 23, 2010
    737
    150
    You gave a formula relating voltage, current and power NOT power, current & resistance.
  10. PSnetwork
    Apr 1, 2013
    30
    actually not, im beginner in electronics.
  11. crutschow
    Mar 14, 2008
    13,518
    3,386
    The speaker voltage is provided by the amplifier driving the speaker with a sound and the voltage value is determined by how loud the sound is.
    What is the purpose of the question? Why are you trying to determine the speaker current?
  12. wmodavis
    Oct 23, 2010
    737
    150
    I= P/R ^1/2
    You gave power = 20 W rms
    On the graph of speaker impedance vs frequency pick a frequency then find the speaker impedance on the graph.
    Then plug those values into the formula I provided above and solve for the current. So if that is really what you want you can calculate it.
  13. #12
    Nov 30, 2010
    16,705
    7,358
    The simple answer comes from 20 watts, 8 ohms.
    P=I^2R
    20 Watts = current squared times resistance
    20W/8 ohms = current squared
    square root of power over impedance = current
    1.58 amps is the current, continuous and
    from 80 watts peak, current is 3.16 amps.
    This is a very simplified form, but it is enough to try to fit a fuse for the speaker.
    I think 2 amps, slow blow, would be about right, but I'm not the best at fuses.
  14. PSnetwork
    Apr 1, 2013
    30
    im trying to find the speaker current for calculating for how much time the power will be on with 5A/h SLA Battery. i found the solution below, thanks anyway.
    thanks you guys that what i've asked. THANKS.
  15. bountyhunter
    Sep 7, 2009
    2,498
    507
    No, you haven't. The average current from the battery will probably be less than 5% of what you would calculate from the 20W figure. The 20W value on a speaker is absolutely meaningless for power consumption it's a rating where the voice coil melts.
  16. t_n_k
    Mar 6, 2009
    5,448
    783
  17. PSnetwork
    Apr 1, 2013
    30
    Sorry but my english is sucks. can you explain in a better way?
  18. #12
    Nov 30, 2010
    16,705
    7,358
    You have discovered how to calculate the highest amount of power the speaker can survive. You have nearly nothing about how much power the amplifier will send to the speaker.
  19. PSnetwork
    Apr 1, 2013
    30
    Amplifier is 40W RMS max power. 2 speakers running, each one is 20W, so they will draw something like 40W in full power i guess. Isnt it good?
  20. bountyhunter
    Sep 7, 2009
    2,498
    507
    No, that's wrong. There is no way they would consume anywhere near 40W average power. You don't get the fact that speakers are rated in peak power and you won't be using anywhere near that power when playing music. I would be very surprised if you used more than 1/2W average power even listening to loud music.
