coukd you better explain measurement principles ? I suppose with vector network analyzerI would use a Vector Network Analyzer. Problem is, they cost as much as a small house or a large vehicle.
thank u so muchA VNA with an s-parameter test set is programmed to stimulate a device under test and measure the transmitted and reflected reflected signals. In the setup we had, a transistor was put on a jig designed for this purpose, connected to the unit, and the data was collected and displayed on a Smith Chart or other graphical displays such as return loss.
Here is where I would start for getting a handle on how things are measured.
https://en.wikipedia.org/wiki/Scattering_parameters
http://www.keysight.com/en/pc-1000003159:epsggr/discontinued-s-parameter-test-sets?cc=US&lc=eng
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Aaron Carman
