How to measure offset voltage and polarization currents of an op amp?
Discussion in 'Homework Help' started by msr, Mar 23, 2009.
  1. msr
    Thread Starter Active Member
    Jul 8, 2008
    62
    The title says all.
    Can you please sugest me an experimental procedure to determine the offset voltage and input bias current of a 741 opamp and also ?
    Thanks in advance!
  2. Ron H
    Apr 14, 2005
    7,050
    657
    Polarization current is not a normal op amp specification. Do you mean offset or bias current?
  3. msr
    Jul 8, 2008
    62
    I mean input bias current.
    Sorry, im portuguese and that was a bad translation in deed.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    In the Homework forum, you need to show as much work as you can. We'll help you over the rough spots.
