How to measure low capacitances by STM32F0
Discussion in 'Embedded Systems and Microcontrollers' started by DZenkin, Dec 16, 2014.
  1. DZenkin
    Dec 16, 2014
    Hi everyone!
    Recently I've started to describe some of my embedded projects on my blog:
    http://cortexdev.blogspot.com
    Currently I posted some explanation about using Cortex core in measuring low capacitances with practical example on STM32F050 chip . Any suggestions and questions are welcome !
  2. MrChips
    Oct 2, 2009
    12,636
    3,454
    You need to specify the range of capacitances and the resolution you hope to measure.
  3. ErnieM
    Apr 24, 2011
    7,438
    1,626
    You should also specify the range of capacitances and the resolution you hope to measure.
    DZenkin and MrChips like this.
  4. MrChips
    Oct 2, 2009
    12,636
    3,454
    Sorry, there is something wrong with my mouse. I repeatedly get three postings and have to manually go back and delete the duplicate posts.
    Shall we say my mouse is chattering or has too much bounce?
    ErnieM likes this.
  5. DZenkin
    Dec 16, 2014
    Range of capacitances started from 15-20pF with only one diode and resistor at hardware part.
    Resolution depends on capacitance, from 7-8bit on 20pF delta.
  6. ErnieM
    Apr 24, 2011
    7,438
    1,626
    Dang it, you deleted the duplicate post. Now my reply sense it makes not.
    But I already have two likes on it so I'm leaving it.
    SO THERE !!!
  7. DZenkin
    Dec 16, 2014
    This numbers derived from the project that already works and show not more than 2.5% nonlinear deviations.
    However, I really hope that method usable from 5pF, but in that case initial non-linearity vastly rises.
