I could use your collective expertise in trying to figure out how to safely measure up to +10KV by "piping" it through a Bud Box (Aluminium).
I have a High Voltage Probe (rated +40KV)/ DVM combo.
The Power Supply has a High Voltage Cable coming out of it that I plug into the box. The Probe plugs into the Bud Box also (with the appropriate High Voltage connector spliced in).
Inside the box, the High Voltage input is wired directly to the Probe Terminals.
The idea is for the Operator to walk around (multiple stations) with the Bud Box/Probe/DVM, plug in the a Power Supply and measure the High Voltage.
First attempt failed when I turned on the Supply.... Arcing like crazy inside the box. I thought I had enough spacing inside the Box... how far can HV jump? What is the best way to insulate? Or use a non-conductive box?
Appreciate any help.
