I've been trying to measure several characteristics of an NMOS without success. I need to know how to use a curve tracer or o-scope (using electronics workbench and the real equipment) to make the following measurements: I-V family
Threshold
Transconductance curve
Pinch off voltage
Gm(gain)
I also need to obtain the following measurements using a BJT: Diode curve, Base turn on voltage, I-V characteristics, early voltage and beta(gain).
I'm really confused about how to do this, I believe in each case i'm supposed to connect the transistor in series with a resistor and then take the readings but i'm not getting any results. I'm not really sure how to set up the circuit and equipment to get these readings. Someone please help!
Threshold
Pinch off voltage
Gm(gain)
