How to measure Hie of bootstrap circuit (common emitter)
Discussion in 'Homework Help' started by Watershadow, Jul 10, 2011.
  1. Watershadow
    Jul 6, 2011
    9
    The text book I am using just assumes that the Hie is 2k. But says that its too complex to go into the detail for working out the Hie. Is there a specific way to work it out so that you would get roughly 2k specifically in a bootstrap setup for a common emitter.
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    Show as the diagram
  3. Watershadow
    Jul 6, 2011
    9
    Not really sure how, thats why I am asking.
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    What book you are using.
    And can you show as which type of the boostrap circuit you are talking.
    This type of the circuit
    In general case the Hie is BJT input resistance.
    and Hie is always equal to
    Hie = (β +1)*re = (β +1) * 26mV/Ic
    So what is your definition fro Hie ??
      File size:
      8.3 KB
      93
  5. Adjuster
    Dec 26, 2010
    2,147
    300
    Normally you would understand hie as a parameter used in a model for a transistor by itself :-
    hie= hfe*re, where re = 0.026/IC (approximately, at room temperature)
    You might therefore get a value of around 2kΩ with a typical transistor operating with collector currents of a few mA.
    If your text is applying h-parameters to describe the complete bootstrapped stage, that would be another matter. You would really have to supply more information to get a definite answer.
  6. Watershadow
    Jul 6, 2011
    9
    The text book is called Analogue Electronics : Design principle by Nico J. Oosthuysen.
    Personally I think its a badly written book and I am studying in South Africa and the book is South African. It doesnt even show any information about Hie, I had to look online, but there is nothing about bootstrap and Hie. There are 2 resistors by the Emitter side with a capacitor connected across the one closest to the transistor. Will this make a difference to the formula considering there are now 2 "Re" resistors?
  7. Jony130
    Feb 17, 2009
    3,990
    1,115
    The diagram looks like this?
    Or maybe this way
    But this circuit has nothing to do withe the bootstrap
      File size:
      9.5 KB
      75
      File size:
      9.4 KB
      73
