How to measure electric power?
Discussion in 'Electronics Resources' started by ArFa, Oct 1, 2013.
  1. ArFa
    Apr 24, 2011
    9
    Hi all,
    I want to measure output voltage, output current and output power of a 3-phase power generator, and send those data to MCU, how can I do that ?
  2. Alec_t
    Sep 17, 2013
    5,971
    1,135
    What nominal voltage/frequency?
  3. ArFa
    Apr 24, 2011
    9
    I think it's 320 V / 60Hz
  4. #12
    Nov 30, 2010
    16,671
    7,314
    3 current transformers, 3 voltage transformers, 6 rectifiers, 6 resistors, and 6 capacitors. These will give you a DC voltage proportional to each current and each voltage.
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    That setup won't give you the means of finding the real power - only the apparent power.
  6. #12
    Nov 30, 2010
    16,671
    7,314
    OK. So go ahead and finish up what the OP needs.
  7. crutschow
    Mar 14, 2008
    13,482
    3,370
    If you need real power then Analog Devices and others have chips that generate an indication of real power from the isolated current and voltage sensors that you would need to add in each phase.
  8. WBahn
    Mar 31, 2012
    18,085
    4,917
    Does the generator have a fourth neutral wire that potentially carries current? If not, then you only need to sense phase current in two wires and the voltage between those two wires and the third. That will let you compute real power very easily and you can get apparent power and power factor without much trouble, either.
    If you are willing to assume that the generator is adequately maintaining the phase voltages and phase relationships, then you can get by with a single voltage measurement to establish your phase reference and just infer the other one.
    If you have a current-carrying neutral, then you need to measure the currents in all three phase lines and the voltages between each of them and the neutral.
