How to measure device output that is an "mA" output?
Discussion in 'The Projects Forum' started by MikeA, May 25, 2016.
  1. MikeA
    Jan 20, 2013
    125
    17
    I have a device that has an analog output that I would like to measure it with a 5v Arduino. The output is rated 5-50mA.
    How would one go about measuring current? A resistor across the terminals and measure voltage across the resistor? Am I on the right track? :confused:
  2. Brevor
    Apr 9, 2011
    282
    56
    Yes, thats the way it's usually done. A 100 ohm resistor will have 5 Volts across it at 50 ma.
  3. MikeA
    Jan 20, 2013
    125
    17
    That's easy enough. :D
    Now I'm just curious why would some devices have voltage outs and some amps outs? What are the ups and downs of using one over the other?
  4. mcgyvr
    Oct 15, 2009
    4,791
    976
  5. crutschow
    Mar 14, 2008
    13,501
    3,375
    What type of "devices" are you talking about.
  6. MikeA
    Jan 20, 2013
    125
    17
    An HVAC environment monitor that might hang on a wall hundreds and hundreds of feet away from the main control panel.
  7. crutschow
    Mar 14, 2008
    13,501
    3,375
    For that a current-loop (commonly 4-20mA) is often used since it's less sensitive to noise pickup then a voltage signal.
    Also the same current can be used to provide power to the remote sensor, so two wires can provide both power and signal.
