How to measure AMP battery
Discussion in 'General Electronics Chat' started by sendbad, Mar 13, 2015.
  1. sendbad
    Jan 8, 2015
    43
    hi
    i have a lithium battery 3,7 volt
    Unknown number amps
    How can i know her ah number
    or her amper
    thank you
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Discharge the battery into a known load, then measure the current and the time.
  3. Dodgydave
    Jun 22, 2012
    5,158
    772
    have you got a picture of the battery?
    Roderick Young likes this.
  4. sendbad
    Jan 8, 2015
    43
    when i measure the current using mulltimetr not gev me Fixed number
    Different numbers and then disappear
  5. MrChips
    Oct 2, 2009
    12,643
    3,457
    What is the resistance value of your load?
  6. MikeML
    Oct 2, 2009
    5,451
    1,066
    I'll bet you are shorting the battery by connecting the ammeter across it without a series load resistor....
  7. sendbad
    Jan 8, 2015
    43
    Does not have data
    just 3,7 volt
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Then Ohms law tells me that you do not have a FIXED and CONSTANT load. An ammeter is a very low resistance, and could be damaged by doing what you did. Pick a resistor that will give you say 50 milliamps.
    3.7 Volts / .050 Amperes ≈ 75 Ohms
    The ammeter in series with the resistor goes across the battery terminals. Just to be extra safe estimate the power dissipated by the resistor as
    (.050 Amperes)^2 * 75 Ohms ≈ 187.5 milliwats
    So a quarter watt resistor will get warm but not explode.
  9. sendbad
    Jan 8, 2015
    43
    resistance value 20 om
  10. Dodgydave
    Jun 22, 2012
    5,158
    772
    what is the number on the battery
  11. sendbad
    Jan 8, 2015
    43
    series load resistor 20 om shorting the battery
    so what Suitable om using
  12. sendbad
    Jan 8, 2015
    43
    l
    li-ion 18490 3.7 v
    jo1.f18490ro4 340 13 12
    thes all data in battry
  13. Dodgydave
    Jun 22, 2012
    5,158
    772
  14. MikeML
    Oct 2, 2009
    5,451
    1,066
    I'm guessing that size is about 1500mAh.
    If 20Ω (180mA load current) pulls that battery down immediately, then it is totally discharged, and needs charging before you do any more tests.
  15. sendbad
    Jan 8, 2015
    43
    i will do it
  16. sendbad
    Jan 8, 2015
    43
  17. sendbad
    Jan 8, 2015
    43
    i will do it thank you
