how to measure a network resistor ???
Discussion in 'General Electronics Chat' started by angelita, Jan 9, 2011.
  1. angelita
    May 29, 2009
    25
    hi
    i need to know
    how i can measure the network resistor (part# A 104G ) with DMM
    please help
  2. Kermit2
    Feb 5, 2010
    3,841
    962
  3. angelita
    May 29, 2009
    25
    aha and how to connect it to circuit
    do i need to atttach a pin to gnd or power supply
  4. Kermit2
    Feb 5, 2010
    3,841
    962
    Depends on whether you want to distribute a ground referenced voltage or a supply referenced one.
    One usually uses them for convenience, when placing multiple 'pull up' resistors, or needing several LED's with the same value current limiting resistor.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The 104G marking should mean 100k Ohms, 2% tolerance.
    It might have one common pin, or it might have a number of individual resistors.
