So i have this shift register IC 74HC595 and I used it with Arduino many times.
But i want to know if I can use it manually ie using push buttons for clock(pin 11),data(pin14),latch(pin12),clear(pin10) and blank(pin13).
I tried to do it before using the IC 74HC595,8 LED's,5 tacticle push buttons for each pins mentioned above and a 9v battery.But as soon as I connect the 9v batterty the LED's starts blinking randomly even if i don't press any buttons.
Can anyone help me out with this..........
