I am just a beginner, can you help me?
I need to make a simple circuit that the goal is if I am going to turn the switch "off" the LED should turn "on" and vice versa. But the problem is I do not have any idea on how am I going to start it and what are the values of resistors and transistors am I going to use.
I need to connect one resistor each for the collector, base and emitter of my transistor, a battery which will be my source, a "push" switch and an LED where I will see the output.
If you had already done a project like this, please send me the schematic diagram with the values of resistors, battery, LED and transistor that I need to use.
