How to make pin numbers visible in OrCAD 9.2?
Discussion in 'Electronics Resources' started by kender, Jun 24, 2007.
  1. kender
    Thread Starter Senior Member
    Jan 17, 2007
    263
    Colleagues,
    When a new custom schematic part is created in OrCAD 9.2 there is a dialog that asks for part properties such as designator, PCB footprint, name etc. On this same dialog there is a check box “Pin Number Visible”. How can I open this dialog for an existing part and change the properties?
    In particular, I want to take an existing rotary switch part from the Discrete library, add more pins to it, change the pin numbers and make them visible. I can’t make the pin numbers visible, because “Pin Number Visible” was unchecked, when the part was created by OrCAD staff.
    Cheers,
    Nick
