HOW TO MAKE PC VOLTAGES AND MICROCONTROLLER VOLTAGES SAME!!
Discussion in 'Embedded Systems and Microcontrollers' started by hada, Dec 15, 2008.
  1. hada
    Sep 24, 2008
    15
    hi,
    am new to microcontroller.i have been assigned a project of calculator.i am stuck on one thing that when i have to give input through keyboard to microcontroller my pc voltages and 8051 microcontroller voltages are not same.so what device i must use in between them to make my pc and microntroller voltages same.do i have to use voltage converter.please elaborate.thank u.
  2. RiJoRI
    Aug 15, 2007
    536
    26
    First, how are you to communicate with the PC? Through the Serial (RS-232) port, through the printer port, or through the USB bus? The answer to this question will indicate the answer.
    ASSuming the serial port, the easiest way is to use a level-shifter chip, such as the MAX 232.
    --Rich
  3. hada
    Sep 24, 2008
    15
    yup i have to use serial parallel port between pc and microcontroller.thanks 2 u.
  4. hada
    Sep 24, 2008
    15
    and i dont know which port to use?printer port or usb port?what do u suggest to use?
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
  6. nanovate
    Distinguished Member
    May 7, 2007
    665
