How to make PC software to control a RC robot?
Discussion in 'Computing and Networks' started by thar07, Nov 10, 2015.
  1. thar07
    Jan 3, 2015
    71
    I want to make a simple computer software for windows to control a radio controlled robot . Can you tell me how to do it by steps ?
    p.s I have already build a robot without a RF receiver and I want to modify it.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Range, data rate, unidirectional or bidirectional control, your level of experience with RF?
  3. thar07
    Jan 3, 2015
    71
    range : 500m
    unidirectional control
    data rate : no idea
    i have no experience with RF.
  4. MaxHeadRoom
    Jul 18, 2013
    10,833
    2,502
    Might be easier to use an Android device and write an App such as the likes of the Parrot Drone does using WiFi.
    Max.
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    The fact that you put down 500m as the desired range shows you have no experience with RF, or the legalities of using/licensing a radio link. 500m is tough to achieve with the commonly-available, license-free products, with the possible exception of radio-controlled model aircraft hardware. Even the 2.4GHz stuff would likely not be very reliable at 1/2km between buildings in an urban environment.
    What country are you in?
  6. ScottWang
    Aug 23, 2012
    4,925
    777
    I knew there is a new wifi could do the receive and transmission about 8km, but does the recent wifi can do the R/T about 500 m?
  7. thar07
    Jan 3, 2015
    71
    Ok, then what about the 430 mhz band ?
    I'm in Sri Lanka
