I need isolation for safety. current for each output is 1AWhy do they need to be isolated?
If they truly need to be isolated from the 24Vdc input, then you will need to use a switch-mode power supply with transformer isolation between primary and secondary.
How much current?
Is there a large voltage difference between the commons of the input and outputs?I need isolation for safety.
Based on my limited experience:but i need a schematic.
how to stablize voltages of two outputs
Thee re thousands of power supply designs to choose from. Why don't you show us what you have worked up so far, and we'll start with that?but i need a schematic.
how to stabilize voltages of two outputs
by Jake Hertz
by Aaron Carman
by Duane Benson
by Duane Benson
