How to make LDR working identically?
Discussion in 'Analog & Mixed-Signal Design' started by Shubhankar, Jun 30, 2016.
  1. Shubhankar
    Jun 30, 2016
    Hello there,
    I am making dimmer using my Arduino Board for my home. I am using LDR for dimming the light. But I am facing one problem that all LDR's are not working identically. I found that every time I am getting different value on same intensity of light using different LDR's. So how can I achieve this?
  2. #12
    Nov 30, 2010
    16,671
    7,317
    1) Hardware, use resistors to make the LDRs similar
    2) Software, Make a look-up table for each LDR
    3) Start over, Use a better sensor.
  3. AlbertHall
    Jun 4, 2014
    2,261
    448
    Comprehensive, except possibly:
    4) Don't worry about it!
  4. dannyf
    Sep 13, 2015
    2,196
    417
    By calibrating them to the same output under identical lighting.
  5. GopherT
    Nov 23, 2012
    6,304
    4,027
    Any minor change in outdoor light coming into a window will cause a different ADC value. Even reflections of where you are standing relative to lamps and the various reflections in the room - there is lots of possible differences on a minute by minute basis.
  6. #12
    Nov 30, 2010
    16,671
    7,317
    You're thinking on a micro scale. I have a drawer full of CdS sensors, and they are so dissimilar that I have to choose which range I want to work in before I start designing. Less than 1k, several k, dozens of k ohms at twilight levels. This range would look problematic to a software program. As an analog designer, I cope with this in hardware. Find the right range, slow down (integrate) the output to discard small interference factors, go to logic section.
    GopherT likes this.
  7. GopherT
    Nov 23, 2012
    6,304
    4,027
    I just wanted the OP to understand the variabilities within his room with on LDR before tries to match a second to it - what ever his methodology might be or what ever his expectation for his design.
    #12 likes this.
