How to make GBC 65 laminator hotter?
Discussion in 'General Electronics Chat' started by Robin Mitchell, Mar 25, 2012.
  1. Robin Mitchell
    Oct 25, 2009
    738
    206
    Hi everyone,
    I followed the PCB Fab in a box to make pcb's with the laminator they suggested, the GBC-H65. I bought one (£50) and it does bugger all. I opened it up hoping that it was a simple NTC resistor but found that the board is a little complex. Does anyone know how to increase the temperature of the laminator so that it can melt the toner onto the copper clad boards???
    Many thanks,
    Robin!
  2. spinnaker
    Oct 29, 2009
    5,065
    1,164
    I bought the GBC 212 and it has a heat control. I crank it all the way up and it seems to do fine.
    Really tiny boards it seems to have issues but other than that I get good results.
  3. jrm
    Member
    Oct 11, 2011
    38
    I'm not ure about the GBC 65 but with the 220 you can swap the two drive gears which helps a bit.
