How To Make Dc Power Supply ?
Discussion in 'General Electronics Chat' started by abhimanyu143, Aug 29, 2014.
  1. abhimanyu143
    Aug 25, 2014
    211
    After some reading I have made this calculation
    component
    transformer
    diode rectifier
    filter capacitor
    R load
    1. transformer
    primary voltage Vp= 230 Vrms ac
    secondary voltage Vs= ?
    primary turns Ns = 5
    secondary turns Np= 1
    primary current Ip =?
    secondary current Is ?
    R load = 50 ohms
    formula for transformer
    Vp/Vs=Ip/Is=Np/Ns
    secondary voltage
    Vp/Vs= Np/NS
    230/Vs=5/1
    Vs = 46V rms Ac
    secondary current
    Is =Vs/Rload
    Is= 46/50= 0.92 amp rms Ac
    primary current
    Vp/Vs=Is/Ip
    230/46=0.92/Ip
    Ip= 0.184 amp rms AC
    transformer with load
    primary voltage Vp= 230 RMS ac
    secondary voltage Vs= 46 volt Rms Ac
    primary current Ip = 0.184 A rms Ac
    secondary current Is = 0.92 A rms Ac
    2.rectifier
    If we connect single rectifier diode then
    We know following for rectifier
    Input voltage = 46 Vrms Ac
    Input current =0.92 Arms Ac
    I have to find out output voltage, current for rectifier
    Output current for rectifier
    Idc= Vs/RL= (46-0.7)/50=0.906 dc
    Output voltage
    Vdc = Idc* Rload=0.906*50= 45.3 vdc
    3.filter capacitor
    now we know input voltage and current for capacitor
    Idc= 0.906 dc
    Vdc =45.3 vdc
    I want to do some calculation for capacitance
    how to choose capacitor value ?
  2. #12
    Nov 30, 2010
    16,665
    7,313
    Sqrt2 C Er F = I where Er is the allowable, peak to peak ripple voltage, F is the frequency after whichever rectifier design you used, C = capacitance, and I = current to the load.
  3. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Voltage out 46vac x 1.414 = 65vdc.
    Max.
  4. abhimanyu143
    Aug 25, 2014
    211
    I know only frequency 60 Hz and load current Idc= 0.906 dc
    how to determine peak to peak ripple voltage ?
  5. abhimanyu143
    Aug 25, 2014
    211
    I don't know what are you telling ?
  6. #12
    Nov 30, 2010
    16,665
    7,313
    Use the math I gave you. sqrt2 = 1.414 60 Hz = F if you didn't use a full wave rectifier. It's 120 Hz if you did. Either you decide the ripple voltage you want to allow or you decide the capacitor size. The answer comes out of using the formula.
  7. #12
    Nov 30, 2010
    16,665
    7,313
    He is telling you that the RMS voltage of a sine wave will reach a DC peak of 1.414 times the RMS value after it is rectified (minus the voltage lost in the diodes).
  8. MikeML
    Oct 2, 2009
    5,450
    1,066
    The first figure might help you understand the peak voltage that the filter capacitor charges to, and how the value of the filter capacitor effects the ripple. The second figure shows why it is better to use a full-wave rectifier...
      File size:
      250.7 KB
      32
      File size:
      239.4 KB
      31
  9. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    ...And if you want 46vdc as a final result, that would be 46vdc X 0.707 = 35vac required.
    Max.
  10. cl10Greg
    Jan 28, 2010
    49
    I am not sure how set in your design you are, but have you looked at any of the various power supply designer web tools? TI has one, Fairchild, Power integrations, etc...
  11. ISB123
    May 21, 2014
    1,240
    531
    Use 4700uF cap at 80V.
  12. abhimanyu143
    Aug 25, 2014
    211
    primary voltage Vp = 230 v ac
    peak voltage of secondary=65.004 V Ac
    Rms voltage of secondary = 46 V ac
    output of rectifier = 65.044-0.7=64.344 V ac
    main frequency F= 60 Hz
    peak to peak ripple voltage Vr= 2 v
    using formula for capacitance
    C=I load /2*F*Vr
    C=0.906/2*60*2
    C=0.906/240
    C=0.003775 F
  13. abhimanyu143
    Aug 25, 2014
    211
    If my capacitance value is correct then I want to add regulator Ic
    how to do some calculation for regulator Ic ?
  14. #12
    Nov 30, 2010
    16,665
    7,313
    C = Iload /1.414 * F *2
    C = .906/1.414 * F * 2
    C = 53388 uf
    Read the datasheet for the regulator you want. It tells all about which capacitors to use and how to adjust for different output voltages. They are often a little different from brand to brand, so pick one and read about it. Small capacitors are used to keep the regulators from oscillating. Your big capacitor is finished.
    abhimanyu143 likes this.
  15. abhimanyu143
    Aug 25, 2014
    211
    what is 1.414 ? C=I load /2*F*Vr Is it wrong ?
    If I connect regulator I think I need 2 small capacitor
  16. ISB123
    May 21, 2014
    1,240
    531
  17. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    Have a look at the attached PDF.
    Bertus
  18. #12
    Nov 30, 2010
    16,665
    7,313
    On page 8, that PDF goes right into talking about Vpeak, but I can't find where it explains that Vpeak = the square root of 2 times the RMS value of the voltage. Transformers are usually labeled in RMS voltages. ps, the square root of 2 is 1.4142136 according to my calculator.
