how to make basic robot using matlab...??
Discussion in 'Embedded Systems and Microcontrollers' started by RRITESH KAKKAR, Mar 18, 2012.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    Hello there,
    I want to learn How to make robot controlled by MAT LAB.....
    Please tell basic method to connect mat lab to robot simply moving ahead..!!
  2. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Help please!
  3. t06afre
    May 11, 2009
    5,939
    1,222
    If I told you. I want a microcontroller circuit for a robot. Would you be able to help? Probably no. Because I have not given you any any details at all about anything. Then you ask questions in this forum. You must ask your self. What details are needed in order for others to help me. And here you have a lot of room for improvement. Nobody has answer your request because they have no idea of how to help you. And all the "please help!!" in the world can not fix that problem. Please remember that good questions draw good answers
    RRITESH KAKKAR likes this.
  4. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    OK, thanks....
    I mean to say first like how to glow LED at least like blinking or simply on/off working with MATLAB window....
    after this i will like to move forward!!
  5. evilclem
    Member
    Dec 20, 2011
    118
    16
    I would expect Matlab to talk serial to a micro on the robot. However you'd then be better putting all the code on the micro.
  6. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    But how to do this??
  7. t06afre
    May 11, 2009
    5,939
    1,222
    It was not this I meant. You must write more about what your are doing, and how you are doing it. Something like this
    How can you expect us to use time on your problem. Then your effort to describe your problem is next to nothing.
  8. evilclem
    Member
    Dec 20, 2011
    118
    16
  9. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Actually i have seen some video of image processing in bots, so i have no idea how we can make use of MAT LAB to Hardware!!
