thatoneguy
- Joined Feb 19, 2009
- 6,359
I'd STRONGLY recommend getting a "Proper" LiPo charger. LiPo battery chemistry is nowhere close to forgiving compared to NiCd or NiMH. Fire/ruined batteries/leaks will appear if you just try to dump current into it.
There is an algorithm for LiPos that ICs are specially made for that balance constant voltage and constant current. Look for a low cost LiPo charger, otherwise you'll be looking for a battery and a charger.
For the wheels, make sure they have excellent traction. If your robot needs to stop, it should do so immediately, not skid to a stop which would put you over the line and DQ you. Work on the path first, then experiment with different tire sizes and type to get the performance you want from it.
375 RPM seems way too speedy. I'll echo Markd77's suggestion of the 150RPM or maybe the 250 RPM for starting out. Your code may not be able to keep up with a robot going 90 miles per hour.
