How to make a timer?
Discussion in 'General Electronics Chat' started by kate, Feb 22, 2008.
  1. kate
    Feb 22, 2008
    Can someone tell me how to make a timer that would be used to automatically turn lights on and off. Thank you.
  2. mik3
    Feb 4, 2008
    4,846
    63
    How many minutes you want the timer to delay the lamps from lighting and how many minutes you want the lamps to be on before they go off?
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Is your project for low voltage lighting (like under 15V) or for 115/230V?
    If the latter, I strongly suggest that you simply purchase a commercially available timer. They are inexpensive, reliable and safe, something that a home-built timer may lack on all counts.
  4. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    Buy a cheap one at the Walmart would be easiest. Bribing a sibling might be cheaper but more erratic. ;)
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    A complete set of details would help us assist you better.
    hgmjr
  6. G8NPH
    Feb 24, 2008
    if your circuit is a low powered one then use a 555 I.C. as a monostable
