Hello I wonder if anyone could help me please I am making a HH0 Generator (Browns G a s) to hopefully run my car on. But using a Stanley Mieyers type system I need a Pulse Wave (or Width) Modulator (square wave). The only problem is I no absolutely nothing about electronics. I have seen a diagram of what I am suppose to need on You Tube, but I keep coming across things like Charging chokes and other items I know nothing about if I need 1 what sort. This link http://www.youtube.com/watch?v=bqfiAXIs3Xc shows the diagram and a lot of other information but gives no sizes to anything.
The one Mieyers used was ( http://www.youtube.com/watch?v=nOGAkRkCWfA&mode=related&search= ) using 12v and 0.5amps think he also uses a transformer. I was wondering if I used The LW-HVPS v1.1 I no its producing like 30kv and low amps, link:- http://jnaudin.free.fr/html/lwhvps.htm one of the pictures on this web site states 450 mA ( have seen that what makes Meiyers cells different is that he uses volts to build up and the cell with the water an stainless steel plates in to cause a catastrophic break down and so producing a large amount of gas. This break down is suppose to happen like 20k times a second but also need to be a square wave to get the best results.
If anyone could help me with detailed diagrams pictures or anything else it would be very much appreciated could I also ask not to put it in too technical a terms as like I have said I dont no anything about electronics (only just found out which end of soldering iron to use because it burn my fingers on it lol). Reason I asked if LW-HVPS v1.1 as it gives of much higher volts, would this be too much or if i could build it with a range adjuster on it.
Once again Very Many Thanks.
