How to make a low power change over circuit(urgent......), for Arduino.
Discussion in 'Embedded Systems and Microcontrollers' started by Umindu, Sep 3, 2015.
  1. Umindu
    Sep 1, 2015
    25
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    What exactly is this low power changeover circuit supposed to do?
    Is it permissible for there to be some interval where there is no power delivered to the load?
    Is the Power AC or DC?
    Help me out because my crystal ball is in for repairs.
  3. TheButtonThief
    Feb 26, 2011
    219
    38
    Umindu and PeterCoxSmith like this.
  4. Umindu
    Sep 1, 2015
    25
    hmm i need to change two signal wires from my rc receiver (aileron and elevator) to my arduino pin 8 and 9 by using a spare aux channel
    in fact the current is dc
  5. Ramussons
    May 3, 2013
    562
    92
  6. Umindu
    Sep 1, 2015
    25
    thanks but can you help me with a schematic for this
  7. Umindu
    Sep 1, 2015
    25
    please help me with a schematic for this
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I cannot visualize what you are talking about from your verbal description. A diagram would help.
  9. ScottWang
    Aug 23, 2012
    4,925
    777
    This Rds(on) is quite low, it doesn't like CD4066 has 125Ω(datsheet mentioned), I tested it about 80Ω in 5V, but I can't find it in the local store or online store in Taiwan.
  10. Ramussons
    May 3, 2013
    562
    92
    Not sure what you mean. There are quite a variety of Analog Switches that might meet your requirements.
    http://www.ti.com/lit/sg/slyb125d/slyb125d.pdf
    Basically,
    A HI or LO on the Control pin Closes or Opens a contact. Or are you asking for something else?
    absf likes this.
  11. ScottWang
    Aug 23, 2012
    4,925
    777
    Here have a lot, which one you like? ... :D
  12. ScottWang
    Aug 23, 2012
    4,925
    777
    You can draw a clear block diagram and labeling the voltage and current.
  13. ScottWang
    Aug 23, 2012
    4,925
    777
    Thanks.
    What I want to use was in the page 14 and some similar with voltage divider, but those IC seem only can get from TI.
  14. absf
    Dec 29, 2010
    1,493
    374
    Papa's crystal ball is 8 inches in diameter and has an 6" LCD screen inside...:p
    Allen
  15. Umindu
    Sep 1, 2015
    25
    its not clean but yep this is what i wanted to do
  16. Umindu
    Sep 1, 2015
    25
    does this help
  17. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I appreciate the effort that you put into making the diagram, but I still don't quite understand what is going on. I'll just let other folks who are more conversant with RC receivers and hobby servos help you from here.
  18. ScottWang
    Aug 23, 2012
    4,925
    777
    You have to describe some details according to the block diagram, what do you want to control and which one control which one, they also need the arrows to show the control directions?
  19. Ramussons
    May 3, 2013
    562
    92
  20. Umindu
    Sep 1, 2015
    25
    i want to control the arduino and rc receiver with the change over circuit.so by using the aux channel when the aux channel powers the change over circuit the two signal wires going from the receiver to servo most change to arduino to servo.and when the change over circuit is not ON the servo to r receiver must work fine.and when the change over circuit is ON by the aux channel the above mentioned servo to arduino change over most be done.so the arduino controls the servo.please help
