Hi I want to make a led torch which would run on 3v and the battery capacity I haven't decided. Please exclude circuits with toroid coil and ics (except ic555) . I want to run 6 leds and one 1watt led.
Please recommend me some efficient circuits.Well when you have worked out your led power, current and voltage, then you can select the battery for it, and that will show you how big it will need to be.
PR4403 only drives 40 mA.There aren't any, your 1W led is going to take 330mA, so your batteries wont last long, you need to use a led driver chip like PR4403, this will run from a 1.2V nicad.
https://www.google.co.uk/url?sa=t&s...ggeMAE&usg=AFQjCNFKGVARGdqceHqj1nmBlrdfjV40jw
Sounds like three "C" cells are called for.Hi I want to make a led torch which would run on 3v and the battery capacity I haven't decided. Please exclude circuits with toroid coil and ics (except ic555) . I want to run 6 leds and one 1watt led.
by Jeff Child
by Jake Hertz
by Jake Hertz
by Aaron Carman
