How to make a jumper that can be remotely turned on off
Discussion in 'General Electronics Chat' started by 7z7, Oct 18, 2016.
  1. 7z7
    Oct 18, 2016
    Hi
    I have circuit board that requires a jumper be moved from posts 1&2, to 2&3 in order to program it. I want the ability to remotely over net, "switch" the posts back and forth. So I can put in program mode, program it(2&3h, then put it back in "run" mode(1&2),
    I have the board connected via USB to a pc that can rdp into, but have to go to site every time to move the jumper.
    Any ideas?
  2. AlbertHall
    Jun 4, 2014
    2,282
    450
    An SPDT relay would do the job, but the relay will need some power - what's available? - and it will need a control signal - have you got one of those handy? If you are programming this 'thing' does it have a spare output you hijack?
  3. MrChips
    Oct 2, 2009
    12,652
    3,461
    Get an Arduino ethernet shield.
  4. hp1729
    Nov 23, 2015
    2,105
    235
    So many different ways. We need more info about the circuit.
  5. 7z7
    Oct 18, 2016
    Thank you for the fast response! Got me in right direction, looking into both. I'll be back with more details
