How to make a four-way AND gate using only NAND gates?
Discussion in 'The Projects Forum' started by Supervisor, Jan 17, 2009.
  1. Supervisor
    Thread Starter Active Member
    Jan 17, 2009
    32
    As the title of the thread says, how can I make a four-way AND gate using only NAND gates?
    Help would be appreciated!
  2. mik3
    Feb 4, 2008
    4,846
    63
    Take two NAND and put a NAND at their output connected a as NOT gate. Then take another NAND and wire the output of the two NOT gates to its input. Finally, wire a NAND as a NOT gate and put it on the output of the last NAND.
  3. Supervisor
    Jan 17, 2009
    32
    I can ONLY use NANDs.
    No NOT's (unless I am getting your statement wrong).
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If you connect the two inputs of a NAND gate together, it becomes an inverter, sometimes called a NOT gate.
  5. vks_foe
    Jan 11, 2009
    55
    5
    NAND gates are universal in nature.. just give same i/p to both pins... it'll become a NOT gate....
  6. Supervisor
    Jan 17, 2009
    32
    Ah, alright.
    We say, "inverter" over here.
    Communication gap, etc.
    I'm going to start making that now, but can someone give me a picture of what it should look like?
    AHH!! Got stuck!
    "Then take another NAND and wire the output of the two NOT gates to its input. Finally, wire a NAND as a NOT gate and put it on the output of the last NAND."
    What? What two Not gates... Here's what I have so far...
    http://www.fileden.com/files/2008/9/4/2081882/Stuff.JPG
    Sorry about picture quality... Had I saved it to another format you'd probably wouldn't want to download it because of the size.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    Beating the dead horse even more...
