russ_hensel
- Joined Jan 11, 2009
- 825
If the motor is driven by a transistor you might be able to run it ( the motor ) on a single battery with a smaller battery for the 555, say use a c cell for the motor and in series with it a AA or AAA to get the voltage to run the 555.
But why not get a 5 volt wall wart power supply and run the whole thing off of 5 volts. A second 555 timer would let you use pwm to control the speed of the fan, or maybe with good speed control you would let it run all the time.
