I am using a PSOC 1 device(8Y8C27643) that is powered by 3.3 volts, attached is the schematic. The ULN2003 is right not doing the switching but I can't use this current design cause attaching a load when I get a high output will divide the voltage. Pretty much the microprocessor will give a signal and I just want to amply the signal if I want it at an "ON" state or 0 volts if it is at an "OFF" state. This project has about 8 ouputs coming out of the ULN2003. My schmatic is attached.
