How to make a 555 timer control a relay?
Discussion in 'Homework Help' started by Squerl101, Sep 25, 2012.
  1. Squerl101
    Sep 25, 2012
    Hey guys,
    For my project, I have made a turn signal-like flashing circuit. It runs on 12 volts, and has 4 LEDs that fill up like a loading bar when 12 volts is applied. It clears out when no voltage is there. That's what makes it look like a turn signal. So what needs to happen is I need to make another 555 control a relay that turns that circuit on and off, making it look like a turn signal :confused:. If someone could link me to a schematic, that would be great. Thanks!
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Not sure what your after, but you can use pin 2 and 6 from the 555 as an analog signal, it is a ramp.
    Bill's Index
    I have several 555 sources in my blog. I am one of the 555 experts around here. Show us your schematic.
  3. Squerl101
    Sep 25, 2012
    Thank you, sorry about the lack of info, I want the relay to be able to click on and off like a car flasher.
  4. ScottWang
    Aug 23, 2012
    4,933
    777
    Maybe you don't need a relay on your circuit.
    You only add a NE555 Astable Oscilltor in front of your circuit, the NE555 will output a Square wave 0V and 12V(around), it can be drive your circuit.
    You can adjust R2 value to match your need.
