How to maintain IP Rating after cutting the Box?
Discussion in 'General Electronics Chat' started by Emir Sade, Jan 14, 2016.
  1. Emir Sade
    Oct 12, 2015
    We are using Graphical LCD in IP65 plastic enclosure. We cut the IP65 box front panel for GLCD's display space. How to maintain the IP65 rating after cutting the space on the boxes for GLCD Display??? What's your solutions/methods for this job?
  2. Brownout
    Jan 10, 2012
    2,375
    998
    What's a IP65 rating?
  3. cork_ie
    Member
    Oct 8, 2011
    348
    58
    Glass or perspex bonded with a good quality adhesive sealer such as Sikaflex https://www.sika.com/ or Tec7 http://www.tec7.com.
    They both have a wide range of products that will cover your needs.
    Available in black, white and clear.
  4. cork_ie
    Member
    Oct 8, 2011
    348
    58
  5. strantor
    Oct 3, 2010
    4,302
    1,989
    if your LCD is IP65 rated and you followed the cutout/mounting instructions then your enclosure is still IP65 rated. If your LCD is not IP rated or you did not follow the instructions, then your enclosure is no longer IP-anything rated and there's nothing you can do about it. You could slather a puddle of caulk over the whole thing and make it so it doesn't leak, but you can't keep calling it IP65. Once you violate the IP rating by installing a non-IP-rated fixture, it's null.
