how to maintain constant voltage mode across mosfet /igbt ?
Discussion in 'Power Electronics' started by kittoo, Aug 1, 2016.
  1. kittoo
    Jul 11, 2016
    26
    Hence the mosfet circuit will be operated at active region for constant current mode,then what about the constant voltage mode for battery charger applications?
  2. #12
    Nov 30, 2010
    16,703
    7,341
    The first thing I thin is, The goal of a battery charger is to provide a constant voltage across the battery, not the mosfet. Without a circuit diagram, I can't understand what you are asking.
  3. kittoo
    Jul 11, 2016
    26
    Thanks for reply,
    I don't have any circuit diagram,just asking whether mosfet or igbt will provide a constant voltge.
  4. #12
    Nov 30, 2010
    16,703
    7,341
    Not all by their self. A circuit can provide constant voltage, a shunt regulator can provide constant voltage, but a mosfet or an IGBT can not do this all alone.
    kittoo likes this.
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    If by active region, you mean the highlighted region shown here for a typical mosfet:
    Note that in that region, the mosfet behaves like an Ohmic device. As current increases, the voltage drop across the Drain-Source increases and visa versa. Therefore, by itself, it will not provide constant voltage anymore than a resistor would.
    John
