How to light LEDs
Discussion in 'General Electronics Chat' started by meijaz, Sep 26, 2010.
Thread Status:
Not open for further replies.
  1. meijaz
    Nov 20, 2009
    37
    I want help on lighting 9 white LEDs from mains. These LEDs are fixed in parallel. First I lit them with 5V power supply and noted the current from DMM to be 500mA and they worked fine.
    Now I want to light them from mains (220 V). I assumed a simple circuit with a resistor in series. I calculated that the value of the resistor should be 500 ohms. Finally I connected that resistor, the LEDs and a fuse to the mains. Suddenly, the resistor burned out then the LEDs exploded.
    Can anyone tell me what am I doing wrong? why did this happen? How can I light LEDs from mains?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    What you are trying to do is extremely unsafe, a transformer must be used to help you on this site. It is a core rule here.
    Things that close your thread
    I have an article on LEDs that might or not help.
    LEDs, 555s, Flashers, and Light Chasers
    If you want to discuss how to use high voltage AC through a transformer that is within the rules, but direct connect to mains can kill people , even if you think it is safe. This applies to power supplies too.
    meijaz likes this.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    As Bill_Marsden said, you must use a transformer to isolate your circuit from mains power.
    You can purchase "wall warts" aka "plug supplies" very inexpensively, in various voltage and current ratings. You probably already have more than one sitting around doing nothing in your home. Using a "wall wart" will keep you safely isolated from mains power.
    meijaz likes this.
  4. majsyd2010
    Member
    Aug 29, 2010
    61
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Where is the fun in that? LEDs are among the simplest devices you can build for, and visually gratifying to boot.
  6. majsyd2010
    Member
    Aug 29, 2010
    61
    I agree with you Bill if you are making one for hobby ... But using it as commercial scale, then going for a ready made unit will be a good option.
  7. marshallf3
    Jul 26, 2010
    2,358
    201
    LEDs run on DC, AC line mains are rated in RMS so the actual output peaks you get from them is +/- 1.414 x rated lines voltage.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    Again, this is something we don't do here. What you say still applies to transformers. As long as the OP sticks with safe practice the thread stays open, but we have to follow the rules too. I have to admit I haven't always followed the rules, but I'm much better now.
    ;):rolleyes::D
    Agreed, but nothing the OP has said would hint that it is for commercial use.
  9. sbombs
    Member
    Feb 26, 2010
    33
    Yeah, you calculated wrong.
    If you aren't going to use a low-voltage isolated power supply (the sensible thing to do), at least go and get yourself one of the many made-for-purpose LED drivers. Also, use a step-down transformer (to make a low-voltage, isolated power supply).
    Here's an example: (18 cents at quantity, free samples, etc) Many manufacturers have ready-made led drivers for lighting applications.
    http://www.onsemi.com/PowerSolutions/product.do?id=NSI45020JZT1G
    45 V, 20 mA ± 15%, 1.5 W package, Adjustable Constant Current Regulator & LED Driver, SOT-223
  10. meijaz
    Nov 20, 2009
    37
    V = I*R + 3
    220 = 0.5*R + 3
    220-3 = 0.5*R
    R = 217/0.5 = 434 ohm
    Now I understand that it is better to step down the voltage to a safe value. But what is wrong in this calculation?
  11. marshallf3
    Jul 26, 2010
    2,358
    201
    First of all 220V isn't 220V, see my previous post.
  12. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    We insist you use a step-down transformer to power the leds.
    Bertus
Thread Status:
