how to know the inductance?
Discussion in 'Homework Help' started by onlyvinod56, Mar 24, 2011.
  1. onlyvinod56
    Thread Starter Active Member
    Oct 14, 2008
    362
    hello,
    i have taken a fly back transformer from a computer smps.
    I want to know its inductance on both primary and secondary?
    is there any simple technique to find its inductance(as well as resistance also)
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you have a known capacitor and a signal generator, you can place a resistor in series and use the cap to make a parallel tank circuit with the flyback windings. Vary the frequency until the drop across the LC tank is at it's maximum - http://www.allaboutcircuits.com/vol_2/chpt_6/2.html
    If you have a meter, the ohms function should let you read the resistances.
  3. onlyvinod56
    Oct 14, 2008
    362
    see the attachment..
    My function generator can give 10Vpp, 10MHz sine.
    what will be range of the resistance & capacitor values?
      File size:
      14.6 KB
      24
