How to know how bright to make an undocumented LED
Discussion in 'General Electronics Chat' started by Lectraplayer, Jul 16, 2015.
  1. Lectraplayer
    Jan 2, 2015
    77
    5
    I'm trying to figure out how strong an LED I salvaged is. It looks like a garden variety 1 watt, but the board it was on was marked XS-116. I'm betting it is a Cree XS series, though I never found that part number. If I was to try to find its optimal drive current, how would I know I'm near my rating? Could I go by voltage across the LED? What voltage would I go for, 3.6 volts?
  2. KJ6EAD
    Apr 30, 2011
    1,426
    364
    The ultimate limit is junction temperature but that's difficult if not impossible to measure so the manufacturer relates it to something that is measurable such as case temperature or solder point temperature. Look this information up for a design or designs that match the form factor and apparent thermal mass of your unknown LED, then monitor the temperature while ramping the current up. This should result in an experimentally derived current value that's close to one of the data sheet values. Use that closest matching data.
  3. gbegks
    Jul 15, 2015
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    LEDs are not voltage devices, it is only current that matters.
  5. Lectraplayer
    Jan 2, 2015
    77
    5
    While I knew LEDs were dictated by current, most diodes I have bothered would still have a voltage that correlates to its current, although not directly via Ohm's Law.
    Would the package tell me all I need to know about the LED? All I have seen are good for a junction temperature of 150 degrees celcius.
  6. Lectraplayer
    Jan 2, 2015
    77
    5
    A lot of LEDs have fallen victim to that method, although I have used a big heatsink in the experiment. Do I need to go without the heatsink and measure the back?
  7. KJ6EAD
    Apr 30, 2011
    1,426
    364
    If the type of LED in question normally employs a heat sink then use one. The method I've described is for experimentally characterizing an unknown LED, not a method for long-term operation as you seem to misunderstand.
  8. mcgyvr
    Oct 15, 2009
    4,791
    976
    as stated above..
    Run it at a current (use your best judgement if you think its a 1 watt follow recommended current for those..probably 350mA) for minimum 30 minutes to allow it to stabilize and measure temps the whole time as close to LED as possible add 20 or so deg C and assume thats junction temp.. Keep it under 85 deg C for long life.
    If its way under temps.. crank up the current
    If its too HOT ..crank it down.
    But its a single low cost LED.. not worth the time to even attempt to characterize it IMO..
    Or just post the picture.. More than likely you can tell by just looking at it..
