how to invert sine wave?unipolar spwm
Discussion in 'Homework Help' started by danny2, Apr 1, 2010.
  1. danny2
    Oct 28, 2009
    29
    hi there,i would like to to how to invert -2V of the sine waveform?
    because i want to generate the unipolar spwm to apply n-channel MOSFET to my h-bridge.
    In practically,what is the component that suitable to invert sine waveform with 180 degree with respect to 2V sinewave as show on the figure below.
    by inserting the inverting amplifier at the pin 2 of op-amp,U7?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Your circuit can't work. The 2.5 volt input will overpower the 2 volt inputs, and the outputs are tied to ground.
    An op amp set up as a 1:1 inverter will do what you want.
  3. danny2
    Oct 28, 2009
    29
    i want to make my modulation amplitude=0.8,that's why i set it like that.As you know that the reference sine wave divide by carrier wave is equal to Ma.
    practically,i had try to invert the sine wave in lab by using the op-amp,u741,but still cannot get the invert sine wave.
    how to get the sine waveform as show in the attachment?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Chk Pourya likes this.
