How to Interface with Tiny OLED with 0.65mm Pitch Connector
Discussion in 'The Projects Forum' started by Eric Kubischta, Oct 20, 2015.
  1. Eric Kubischta
    Nov 22, 2014
    21
    I want to drive some very small displays (less than 1 inch wide) and I found these 0.83" and ordered them. Without thinking...
    My question in: How the heck do I interface with this little guy? - From what I can tell in the spec, it is a 0.65mm pitch, 28 pin connector. I cannot find anywhere any kind of female connector for this - so...what do I do? Is there any kind of connector that will convert this to 2.54mm pitch holes so I can mount it to my PCB?
    It seems it has to be soldered on - but I am just prototyping really and can't really etch a board.
    Any thoughts? Here is a pic and a pic of the dimensions, etc.
    http://www.buydisplay.com/media/cat...98182eb6081b1d6/e/r/er-oled0.83-1_outline.jpg
  2. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    No problem to pin these on adapter pcb.
    You need a standard 50w station, a broad tip and have flux ready but often not needed.
    Be careful the gold plating would alloy, so don't solder on it too long.
    On a pcb with pads manual attachment at this pitch is more difficult.
    Basically you add 1mm solder then draw back and forth a few times remove the shorts the same way and press down with the tip a little.
    Using a point tip at this pitch isn't practical at all and the heat conductivity is poor it deforms quick as well
  3. Eric Kubischta
    Nov 22, 2014
    21
    Ok thank you - I will try to find an adaptor PCB - Need one with at least 28 pins
  4. mcgyvr
    Oct 15, 2009
    4,793
    976
  5. Eric Kubischta
    Nov 22, 2014
    21
    Thanks Mcgyvr - I might actually go with one that already is mounted. That schmartboard is cool, but too wide for my design.
    Here is one that is already wired up for about $1.50 more than what the unmounted OLED's were.
    http://www.ebay.com/itm/371306545410
    Slow boat from china on this again.
