how to interface external Samsung NAND Flash With MSP430
Discussion in 'Embedded Systems and Microcontrollers' started by CrackJack, Mar 23, 2011.
  1. CrackJack
    Thread Starter Active Member
    Aug 7, 2009
    127
    hello everyone,
    does anyone has an experience of interfacing external Samsung Nand Flash K9XXG08UXM with MSP 430fxx series uC?
    all i want to do is dump my data from the input ports of uC onto the Flash Memory.
    thanks in advance
  2. CrackJack
    Aug 7, 2009
    127
    does anyone know abt it yet??:confused:
  3. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
  4. CrackJack
    Aug 7, 2009
    127
    yes, i did have a look at the datasheet... i understand the basics of the architecture of the chip. however, I am confused as to how to write to a particular address on the chip? For example, in the ReadCycle, it is mentioned that i have to
    input 2Column Address and 3 Row Address cycles. hw to do these?
    Do you have a sample code which mentiones
    PAGING and how to do it? i never have had experience with 'paging'. can you please help?
    thanks
  5. CrackJack
    Aug 7, 2009
    127
    hello everyone, I decided not to use Samsung Flash but instead using the MICRON 16Gb flash memory. In the memory datasheet, there is a tab for
    Device Initialization..
    attached is the datasheet for the memory. check page 46.
    can any one please tell me what does it mean by Ramping Up Vcc??
    thanks
