How to install systemC on mingw
Discussion in 'Homework Help' started by stereoMatching, Jan 24, 2011.
  1. stereoMatching
    Jan 24, 2011
    As the title, I would like to install systemC 2.2 on mingw
    But I don't know how?
    OS : windows xp sp3
    compiler : htp://tdm-gcc.tdragon.net/
    I spent several hours to find some instructions but can't find a solution
    Could anyone show me a link or tell me how to install this
    line by line?
    Thanks for you help
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Don't the installation instructions work? -
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    If you go to http://www.cygwin.org and install Base + compilers + Ming system/dev/header options, you'll be set.
    Cygwin runs both mingw and native to windows executables, which gives you a shell, compiler, and most *nix commands on a Windows box.
    If you are to use only mingw, follow the instructions by Beenthere. Cygwin is a lot more comprehensive, and free as well.
  4. stereoMatching
    Jan 24, 2011
    Thanks, I install the tdm-gcc long time ago
    But I don't know how to make systemC 2.2 works under it
