how to install spice in windows 7
Discussion in 'General Electronics Chat' started by eritronium, Dec 21, 2011.
  1. eritronium
    Dec 21, 2011
    Do you guys know any way for installing spice on windows 7 ? I need to install it because I´m interested in experimentation
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    I am running LTSpice IV on Windows 7 64-bit; I'm using dual processors with no problems.
    If you are going to install it into the "C:\Program Files" folder, you will need to have administrator priveledges.
    I chose to install it in a different directory, because Windows 7 is mighty picky about letting programs perform writes to those subdirectories of the "C:\Program Files" folder; and I find it annoying to have to deal with moving things in and out of there. I'd gotten in the habit years ago of creating a number of partitions on my HDD, keeping C: just for the OS, D: for temporary files, E: for the swap file, and F: for programs. Windows 7 doesn't mind if you monkey around with the Program Files directory on another drive.
