How to install ac in a dc rv camper van
Discussion in 'The Projects Forum' started by mylestone, Jun 5, 2010.
  1. mylestone
    May 4, 2010
    I have a fair knowledge of dc to ac conversion.I want to know how involved is it to power a large deepcycle battery for ac power in my camper van.I have a 130amp alternator and am thinking of two 210watt solarpanels trying to charge this enormous 12 volt deepcell battery!How do I get the battery to switch from alt to solar cells when I turn off the van moter.will a solar controler work?A diagram would help.
    Mylestone
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, how many Watts do you require for AC power?
  3. Bernard
    Aug 7, 2008
    4,240
    414
    I presume that you have a blocking diode between solar panel and battery so that there is no need to disconnect panel when charging with alternator.
  4. Bychon
    Member
    Mar 12, 2010
    469
    41
    In other words, a simple diode, large enough to handle the solar panel amps, is all you need. One part. Nothing fancy at all.
