Remove U14 (AND2 chip connected to U9). It does nothing but mess this up. This digit should go 0-9, just like digit 1.well the 3 separate switches are for the 3 resets in the 4510 IC, by trial and error, i could do a reset. the fourth 4510 ic am not being able to connect it properly. And why does it start with 00:10? i had a similar problem before but i dont remember what change caused it stopped, i guess it was high voltage or lower frequency.
You changed the connections to the second digit and now it doesn't work correctly. Why can't you enable reset on the 4th counter?the fourth 4510 ic am not being able to connect it properly.
A reminder. This is the Homework Help forum, not Homework done for you...Also, your reset for digit 2 (MM:SS) should look like this.
Yes they are helping only Sir. For me this is great help, because not being electronic students i am not used to these and without these small or big help, i am not going to move ahead at all. AAC is a place where electronic experts help those who dont know as it seems. And i am of those weak in electronic.A reminder. This is the Homework Help forum, not Homework done for you...
Mods edit:
The circuit was deleted, thank you.
Homework is a special case. We are expected to guide you to a solution so you can learn; not do your homework for you.Yes they are helping only Sir. For me this is great help, because not being electronic students i am not used to these and without these small or big help, i am not going to move ahead at all. AAC is a place where electronic experts help those who dont know as it seems. And i am of those weak in electronic.
Examine the reset and clock logic for the last 3 counters. It should be obvious why some of the counters are incrementing when you're trying to reset.There is a problem of increment when i am resetting. The last one increments each time i close the switches. I guess this is because the OR is ORing with the power, something like this and the AND from 3rd 4510 ic! am i correct?
As others have noted (and this is a general comment not directed at you specifically, MrCarlos), the lack of time is almost certainly due to poor planning on the OP's part. That is part of what they are supposed to be learning and if someone comes to the rescue then they are robbed of the opportunity to learn that lesson in an environment where all that is at stake is the grade on a project.Hi ScottWang
I really sorry. I get carried away by the lack of time that the OP has to present his design.
Surely I will not do again.
Look at the reset logic for the last counter. You disconnected it when you were trying to implement reset.evrything was going fine..upon test i found out that it doesnot stop at 59:59 but goes beyond.
by Jake Hertz
by Jake Hertz
by Jeff Child
by Jake Hertz
