How to Indentify terminals of a relay
Discussion in 'General Electronics Chat' started by lpfan, Feb 8, 2007.
  1. lpfan
    Feb 8, 2007
    Plz guys help me i dont know how to indentify the terminals of a relay
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It's hard to give a good reply without any idea of the relay in question. If you have a number on it, then the manufacturer should have the information.
    Do you have any idea of the type and voltage on the coil?
  3. lpfan
    Feb 8, 2007
    Yes I do hv the info on it. It is a 6v d.c. 400 ohms , 150mA, single pole double throw switch. what i want to know is tht how to identify which terminal is the coil terminal and which are the normally closed and normally open ones? Thx fr replying to my thread:)
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Two pairs of terminals will have some continuity between them. One pair will read 400 ohms - that's the coil. The other two will read 0 ohms - that's the common and NC (normally closed) contact. Put 6 volts on the coil, and the common terminal and the one that checked open before will show 0 ohms (the NO, or normally open terminal).
  5. lpfan
    Feb 8, 2007
    Thx a lot man!:)
